ElektroLumens
CPFer's,
(NOTE: I posted this to another thread, and it was suggested to me to start a new thread with it, so here it is.)
I did manage to do a run time test with the MAX757 circuit, and the Luxeon Star. After I started it, I realized I was using an older circuit board, which is only at 77% efficiency. I decided to just continue with the test anyway, because I wanted to start with completely fresh Energizer AA alkaline batteries. I set the output voltage at about 3 volts, and 300mA. Here are the results. I didn't check for input current as I only have one .1 ohm resistor, and it is a hassle to switch it back and forth from input to output.
TIME Vin Vout mA
9:45pm 2.885 3.015 300mA
9:51 2.701 3.003 280mA
9:58 2.597 2.996 270mA
10.05 2.509 2.989 270mA
10:14 2.424 2.986 260mA
10:24 2.348 2.979 260mA
10:46 2.211 2.969 250mA
10:58 2.142 2.965 240mA
11:15 2.073 2.960 240mA
11:35 1.988 2.955 230mA
12:04 1.755 2.939 210mA
12:15 .573 2.637 100mA
12:15 Shutdown.
Ran for over 2 hours at full brightness or near full brightness. Even at 230mA, the Luxeon is still fairly bright.
I will do the test with 'C' batteries (gotta start earlier!!). I can also do it with 'D' cells. I do not have any rechargables, and it is not a good idea to run them down too far anyway.
I suppose that the 'C' batteries would last 6 hours, and 'D' cells should go for 12 hours. Perhaps longer because it is easier for the larger batteries to supply the heavy current. Also, I need to use the 83% higher efficiency MAX757 circuit next time.
Hey, this can get expensive, doing these tests!
It seems like the regulator leveled out for a bit at around 270mA to 240mA. I guess we could toss this around and find a optimum setting for long battery life. I think the rules change with nimh. I think the higher efficiency regulator shoud make a difference, possiby 6% better. After 2 hours and 20 minutes, it was still pretty bright. It faded out real quick in the last 10 - 15 minutes or so. Add 8 minutes to the run time (6% of 140). If we set the regulator down to 270mA, we might attain 3 hours. ??
Wayne www.elektrolumens.com
TIME Vin Vout mA
12:15 Shutdown.
![grin.gif](/proxy.php?image=http%3A%2F%2Fimages%2Ficons%2Fgrin.gif&hash=2eae8867e5fb862b4a9167d602db5752)
