Test/review of Molicel INR18650-P28A 2800mAh (Gray)
HKJ
Copenhagen, Denmark
Official specifications:
  • Typical capacity 2800mAh
  • Minimum capacity: 2600mAh
  • Nominal voltage: 3.6V
  • Standard charge current: 2.8A
  • Maximum charge current: 6A
  • Discharge cut-off voltage: 2.5V
  • Charge cut-off voltage: 4.2V
  • Maximum discharge current: 35A
  • Internal resistance: 20mOhm
  • Internal resistance DC: 20mOhm (10A/1s)
  • Ambient temperature: Charge: 0°C ~ 60°C, Discharge: -40°C ~ 60°C
  • Typical cycle life: 400 cycles to 80% at 20A discharge.
This is a high current 18650 cell with fairly good capacity.
The two cells tracks very nicely, at 30A the battery got hot and I stopped the test before the battery was empty.
Conclusion
A good high current cell and not that different from the P26A
Notes and links
The batteries was supplied by a reader review.
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
badtziscool
Geez. That is an insane amount of current the cell can provide with less voltage sag at very high current draw compared to Sony VTC6.
