I thought I had the proper Ushio replacement bulb for use in a Maxabeam as I thought others here on CPF had purchased before. Does anyone have a Ushio part number, photo of the bulb, box or any other helpful information about the bulb they used as a replacement? Below are pics of the clone bulb and the Ushio I thought was correct. The original clone bulb metal bases are both the same size. One end fits down into 12 "springy" contact fingers at the base of the reflector. The other end attaches to a sleeve with a spring in it and then another small sleeve slides into that. This allows the focusing mechanism to function without allowing the bulb to drop out of the guide pin on the front glass.
The Ushio bulb bases are two different sizes, the one that is supposed to go down into the base of the reflector is too small and does not contact the 12 fingers. The bulb can't be flipped because it is DC powered and polarity sensitive, or so I believe based on what I've been told about DC HID bulbs. The overall bulb length is 5/16" shorter. The part number on the base is UXL75XE. With some machined parts, it could probably be made to work. I'm just after whether this is the bulb that others have used?
Any help would be appreciated.
Original bulb and spring sleeve ***'y on top, Ushio, lower
