Doh!Nut
I am just wiring up a MaxFlex for use in a helmet light.
2Series Li-Ion to 1* Series MC-E.
I want to wire it up with a remote switch and statLED so when the light is mounted on my helmet the switch/LED is down by my temple so the switch is accessible and the statLED is just in my peripheral vision.
I completed the wiring as instructed
Led+ to LED+
Led- to GRD (one of two - the closest one to LED+)
Power Positive in to Vin+
Power Negative to GRD (second of two - furthest from LED+)
I stripped back a few mm extra to allow 3-4mm wire to poke through the through hole.
Two pieces of solid copper wire twisted together about 6" long connected stat to LED anode LED cathode to GRD (the wire poking through the through hole.
Switch was connected by two 6" wires between SW and GRD (wire poking though hole) ((The instructions say max 4" leads for switch but I have used this twisted wire arrangement on a similar light))
I then shrink wrapped the stat LED and the switch wires together and tested - and it does not work.
Well, on power on there is not the warning flash (like I get with B-Flex), the main LED lights and stays on and the stat LED gives one flash. The LED can be turned on and off with a clic (not a press) and sometimes I can get it go brighter.
One time I got is to go a bit brighter - press - a bit brighter - press - a bit brighter.
What I think is happening is the rapid flash of the status LED is being picked up by the switch wires and entering the menu system, so I removed all but 1" of the heatshrink and separated the LED and Switch wires but no improvement.:shrug:
So tonight I will try to separate the remaining wiring and see if that helps, the only thing I have done "wrong" (I think) is to have the switch wires too long.
If I cut the switch wires back to 4" will it really make much difference
Does twisting the wires together prevent it from being an aerial - or just make it worse
Can the switch and statLED wires run parallele at any point - ie leave lamp through same hole
Can I use tripple core (R/C servo ) wire to use a common ground to reduce number of wires or should I be using the other GRD
Any advice
Cheers
Nick
