I have an MC-E coming in for another light, and was planning on building Martin's Circuit #10 (switch between voltage double and bridge rectifier).
But I was thinking the other night, and after sketching it out, I think it should be possible to set up a DPDT switch to change the wiring of an MC-E between 2s2p and 4s. And just front it with the basic bridge rectifier circuit. Would this give me much the same effect of circuit 10, minus the boost and smoothing that Martin's circuit provides?
If I understand things correctly, when the MC-E is wired 2s2p, it should have the same voltage and current requirements as 2 LED's in series, except that each LED will only see around 250ma, but the full voltage. So this should be no worse than what we see with 2 LEDs in series on a basic rectifier circuit. Once the speed picks up, you could switch it over to 4s, and get the full 500ma through each led. So that at all times, all LED's are in use.
Are there any drawbacks to this approach? Am I missing something? It seems that if you're using circuit 10, you are switching the LED's very briefly anyway as you go from doubler to rectifier, and the LED's tend to be more efficient in terms of light production when the current is lower.
Thanks for any advice,
Steve
Steve
