Mc2s resistor values***UPDATE***
K-T
*Moderator*
Germany
I was going to create a table with the used resistor values in combination with driver and LED used but failed in doing it via InfoPOP. Nevertheless I think it would be wonderful if these who own one of his MiracleTailcaps (M2S they are called I believe) would post their combination of resistor value, driver, led, battery setup and short description of beam quality/usefullness in low/high setting.
My goal will be to setup a table either here or via link accessable for these still in search for the right resistor value.
What other additional info is useful to catalogue the
resistor values?
Let's make this a useful database. /ubbthreads/images/graemlins/wink.gif
Klaus.
UPDATE 16.09.2004
Re: McGizmo 2-stage tailcap resistor values
K-T, /ubbthreads/images/graemlins/bowdown.gif that would be great! In numerous E-mails, I am also asked about expected runtimes on low. /ubbthreads/images/graemlins/icon15.gif I admit to doing a few runtimes but I don't have the time, batteries or patience (let alone combinations) to try to do this myself!
Thanks and I hope members can contribute to this!
No problem, Don.
I, too, rely on our members to contribute what they have experienced here as I don't have any of these.
K-T,
Well we *should* do something about that! /ubbthreads/images/graemlins/nana.gif
Already saving the pennies - but that's not subject of this thread. /ubbthreads/images/graemlins/wink.gif
Hmmm, hopefully by tonight when I'll check on this thread it'll be more than a conversation between you and me. /ubbthreads/images/graemlins/grin.gif /ubbthreads/images/graemlins/icon15.gif
Hey, It can be *our* special place! /ubbthreads/images/graemlins/grinser2.gif
I was going to provide some guesstimates based on my measurements, but now I think it would be better to leave this place to you guys /ubbthreads/images/graemlins/tongue.gif
kj,
Get your a$$ back here! /ubbthreads/images/graemlins/nana.gif
I'll start off with what I decided I thought worked best:
1x123 with boost driver -15 ohm
2x123 with step down & Lux III - 60 ohm
2x123 and boost driver 5W - 22 ohm
3x123 and step down driver 5W - 30 ohm
OK. I guesstimated the runtime and lux@1m using magic formulas (don't ask /ubbthreads/images/graemlins/wink.gif) You may think it's too vague, but I want to be on the safe side /ubbthreads/images/graemlins/grin.gif
You may check out my McE2S page for the data I used for this estimation.
2x123, Downboy, Luxeon III, PR/PR-T/Aleph 1
15 ohm: 7~11 hours, 750~1150 lux
22 ohm: 10~15 hours, 550~850 lux
30 ohm: 13~21 hours, 450~650 lux
60 ohm: 27~41 hours, 250~350 lux
Badboy, 1x123, Luxeon III, PR/PR-T/Aleph 1
15 ohm: 11~18 hours, 150~250 lux
22 ohm: 16~25 hours, 110~180 lux
30 ohm: 23~35 hours, 80~120 lux
60 ohm: 48~73 hours, 30~45 lux
Badboy, 2x123, Luxeon V, PR/PR-T/Aleph 1
15 ohm: 4~7 hours, 130~190 lux
22 ohm: 6~9 hours, 80~130 lux
30 ohm: 8~13 hours, 60~90 lux
60 ohm: 17~26 hous, 25~45 lux
KL4, 2x123
15 ohm: 5~9 hours, 80~120 lux
22 ohm: 8~13 hours, 60~90 lux
30 ohm: 11~18 hours, 45~65 lux
60 ohm: 23~35 hours, 20~30 lux
I'll update this table as we get more actual data.
---EDIT---
(9/2/2004) Lowered the L4 lux readings because Don's chart reminded me that my L4 would be 30~40% brighter than average L4's.
[ QUOTE ]
KL4, 2x123
15 ohm: 5~9 hours, 100~150 lux
22 ohm: 8~13 hours, 75~110 lux
30 ohm: 11~18 hours, 55~80 lux
60 ohm: 23~35 hours, 25~40 lux
[/ QUOTE ]
/ubbthreads/images/graemlins/bowdown.gif /ubbthreads/images/graemlins/buttrock.gif /ubbthreads/images/graemlins/thanks.gif
/ubbthreads/images/graemlins/happy14.gif /ubbthreads/images/graemlins/happy14.gif Exactly what I looked for!
Could you estimated runtime and brightness with Pilas?It would be very useful!
Thanks ! /ubbthreads/images/graemlins/goodjob.gif
kj, your list made my work much easier - thanks a lot.
The lux readings are very useful to compare each light, neverthess a subjective description and maybe comparison to some known lights could be useful, too. What do you think?
Sebstien, do you want to know the runtime on the low setting? Brightness shouldn't be different no matter if you use 123A cells or Pilas, it just depends on the driver and if a strange setup of batter-driver-luxeon could drop into DD instead of regulation.
Klaus.
Sebast,
I don't have Pilas. Sorry.
K-T,
I believe that both the brightness and runtime will be different between 123A and Pila. As you said, the Badboy and Downboy will be in direct drive when resistered. This means that the LED will be driven at BatteryVoltage - Current x SwitchResistance - VoltageDropAtConverter. The battery voltage is the primary factor here.
JFYI, Madmax converters will not be in direct drive even with these range of resistors.
That's what I was trying to say - the knowledge and experience was just missing. /ubbthreads/images/graemlins/icon3.gif /ubbthreads/images/graemlins/wink.gif
kj,
You are the MAN! /ubbthreads/images/graemlins/bowdown.gif /ubbthreads/images/graemlins/thumbsup.gif At some point soon, I want to give you a "sticky" that will be your thread and none of *us* will be allowed to post! With the proper threat of the wrath of Darell and other means of intimidation, thethread can be left open but only you will post images, evaluations and observations! K-T will also be allowed in to bring the fruits of this thread along.
I have only this to contribute:
sorry, no runtimes on low ...
Don, dito for KJ's thread!
bernhard
kj, your webpage is impressive. Tons of useful information about the M2S with excellent and helpful pictures. /ubbthreads/images/graemlins/bowdown.gif /ubbthreads/images/graemlins/clap.gif
More interesting than runtime on low is useability of the Low-setting in my opinion. I see the M2S as a feature or addon. The light came without it and there is only one output level and runtime depends only on the time the light has been left switched on. By adding the M2S I am rather looking for an additional lowoutput than to push my runtime. The increased runtime could be seen as a positive sideeffect of course. /ubbthreads/images/graemlins/grin.gif
Klaus.
Thanks K-T and kj for answers /ubbthreads/images/graemlins/smile.gif
I'll order somes differents values and test on pilas.
Anyone not shy enough to post Pila 150s or 168s or 17500 values? /ubbthreads/images/graemlins/blush.gif
I have a McE2S with a 22 ohm resistor, and obtained the following intensity values on a SureFire KL4 with known-new BatteryStation CR123A cells:
KL4 on "high": 500,000mcd
KL4 on "low": 52,400mcd
Let me throw a Pila 168S rechargeable cell with unknown prior usage in there and remeasure...BRB...
KL4 on "high": 490,000mcd
KL4 on "low": 13,000mcd
The "high" value is almost the same as it was on disposable cells; but the "low" value is considerably lower.
