Mini Mag LED and reverse polarity
ebow86
Pennsylvania
I was screwing around earlier with my mini mag LED (rebel LED). Anyway I had this really old set of panasonic alkalines that had basically no juice in them. Not paying attention I accidently put the last cell in backwards. Turned the light on, nothing. Removing the cells I realized my mistake. I put the batteries back in correctly, it works, although extremely dim because the cells are so weak. I then put new duracells back in, everything is fine, no issues. I don't understand, this light isn't supposed to have reverse polarity yet everything is normal, nothing harmed. I've read that if you mix up the cells you will fry the LED. So why didn't that happen? Is it ok because the cells were so drained and dead? Or does one have to put BOTH cells in backwards to do any damage? What gives?
That's because the positive contact is recessed in a groove so that if you put two batteries in backwards the negative end of the battery will not make contact. You can pop the module out to look at it if you don't believe me. It's really simple to do: just press down on the silver metal ring with some pressure (take the batteries out first!) and it should just pop out and fall out through the body tube.
What you describe wouldn't hurt the light even if it has no reverse polarity protection.
It's because you only put one battery in backwards.
I don't know how many batteries your light takes (you didn't say) but let's just say it takes 2 batteries. Let's say each battery has 1 volt in it right now. Essentially a backwards battery = negative voltage (because it wants to make current flow in the opposite direction to what we consider the correct direction). If you put both batteries in the right way, then the voltage being supplied to the circuit is 1 volt + 1 volt = 2 volts.
If you put one battery in the right way, and one backwards, now you have 1 volt - 1 volt = 0 volts. So you see there is no negative voltage, so it doesn't matter if the light has reverse polarity protection. This would have no effect on any flashlight regardless of the circuitry.
If you had put both in backwards you would be supplying -1 + -1 volts = -2 volts. Now you are supplying negative (reverse) voltage (with reference to the circuit's correct polarity). This might damage the light depending on the circuitry.
Another example of what wouldn't damage the light is if the light takes 3 batteries and you put 2 in the right way and 1 in backwards. 1 + 1 - 1 volts = 2 volts. The light would be dim but work, and no reverse voltage would be applied to the circuit, no danger of hurting the light.
I think he said he put the last battery in backwards, I think what you're saying would apply if he put the first one in backwards.
Yeah, I read that but I was giving a worst case scenario type of reply.
Oh yeah good point, if he did put both or all 3 batteries in backwards, the first cell wouldn't make contact right? So no matter what you're pretty safe :)
Not a bad design.
minimags come in two sizes...
If its a 2AA light, last cell backwards: 1.5V + -1.5V = ~0V [1.5 = nominal, your cell will very] chances are its + or -0.1V...which wouldn't matter as it is within range of the voltage drop across the driver.
if its a 3AA light, last cell backwards: 1.5V + 1.5V - 1.5V = ~1.5V...but its still in the positive range...so it could have been dim
Only way you'd check if reverse polarity protection exists is to load both cells backwards, but its a one way ticket as I have heard of users previously frying luxeon Minimags:ohgeez:
