Mini Mag SSC P4 mod
i have used the KD driver with an old LED which is Edison Opto KLC8,and it is not bad either,curently i have one to let go at CPFMP.
It's the one on the right
KLC8 with KD driver on the left vs SSC P4 U2SVOH
If you crop the photos to remove all of that wasted, empty space, then effectively you will achieve a zoom. But still better to put your camera in macro mode and take closer-in photos. If you are using the flash, it is probably better to turn it off and use the ambient lighting. The flash tends to wash out details due to excessive reflected light. You can also combine each of the multiple posts that contain just one photo each into a single narrative post. Makes it a lot easier for folks to reference your instructions by linking to just one post instead of a slew of them.
Nano, what drive current are you using for that GD driver?
Thanks for the suggestions about the pics and how to post. This is the first time I have ever posted anything so I learning ho to do it best. I will try to fix what I believe are the most critical pics later today.
The GD that i'm using is 1A.
Sandwich Shoppe still has the parts for a nice looking sandwich, though not as good of a heat sink as I'd like
I have ordered some reflectors and a couple of those drivers to try from DX and KD. I am looking forward to seeing what can be done with them. I would also like to have different out put settings and was thinking of trying the Nite Ize IQ switch but have heard that it greatly dims the high setting. has anyone tried these or know of another option?
You could try a GDuP boost-buck driver and a TerraLux TCS-1 tail switch.
I do use the Tcs 1 as shown in the mod pics and it is great but just for one mode. I am not familiar with the GDuP boost-buck driver could you post a link.
I am happy with the original mod but will be continually improving it until I get it just right so to speak.
