Mini Mag SSC P4 mod
Dpanther
I am very new to the site so please forgive posting errors and send me in the right direction.
First I would like to thank everyone here for creating a great environment to learn a fun hobby. I first stumbled across this sight while doing research for audio equipment. After a few months of reading up and studying pics and diagrams I decided that I just might be able to do this. I then ordered some parts and made a 3D ssc P4 mag with an amc 7135 1050 ma driver. Since that went well and after building several more I felt ready for a new chalenge. I had several p4's left so I decided to put one on a 2aa mini mag. after much thought measuring and research I figured I could put in a 500 ma micro puck. I used copper bracket that I cut pieces from to solder the wires to since I have no Idea how to solder to aluminum.
If anyone is interested in this project I will try to figure out how to put up pics and make a tutorial. Otherwise thanks for the great site and the hours of fun it has been.
Also I could really use suggestions for a good reflector, for now I stole the one from my terralux upgrade (which was total junk in my opinion) and I want to make several more. aluminum would be nice to help the heat more.
Sounds good! I've always liked the MiniMag, and good mods are becoming rarer by the day.
Pics and beamshots please!
The McR18 Reflectors fit and you can also get some 18x12mm Reflectors on DX which fit pretty well.
I got some of these for my MiniMag 2AA and my cutdown 1xLiIon MiniMiniMag.
You could have bought one of these Oxygen Free Copper Heatsink which were sold in the Custom-Area.
I'm going to put a XP-G R5 in my 2AA with a 1A boost-driver from KD, which has a 14mm board and seems to be perfect.
Re: Mini Mag SSC P4 mod pics
I have pics but am unsure how to add them here.
I would have loved an XP-G but have no Idea where to buy one. For a heat sink I just used a 14 mm one from kai domain it does the trick. After about 15 min the body of the flashlight is warm. This runs on 2aa alkalines or 2NIMH. the NiMH last just above 2 hours.
The driver actually fits in the battery tube. I thought about a 750 ma driver but was concerned that the body could not remove the heat at 1050 ma perhaps the other heat sink would help. A cheaper driver would be nice though as the one I used was $10.
Currently I prefer NIMH batteries and I may build these for friends which would make lithium ion batteries out of the question. I eventually would like to use some lithium ion batteries but I have to learn a bit more first.
thanks for the suggestions I will check them out also I could use help on putting the pics up thanks.
Which KD 14mm driver is this?
Do the above reflectors clear the XP-G (presumably either on an 8mm MCPCB or a trimmed 10mm MCPCB?) and its LED+ and LED- solder pads, and press on the OFC heatsink's raised retaining ring? If the reflectors press against the heatsink's retaining ring, then is the focus correct for the XP-G? I would think that an XP-G on an 8mm MCPCB would be low (I've typically measured an MCPCB thickness of only about 0.8mm). A 10mm MCPCB, which seems to measure right at 2mm thick, could put the XP-G die at just about the same height as a Seoul P4 die.
Here is a comparison shot between my p4 3D mag and the Mini mag
ry%3D400
Looks a great output on your minimag. I made some sandwiches for the minimag with the 2 cell 700ma drivers from Dx but the needed allot of trimming to make them fit in the minimag. I've just ordered some of the Kd drivers to try with some heatsinks I have coming. Will try them with the latest ssc p4's from photonfanatic and some 10mm Xpg r5's from cutter as droppin for gifts.
Rob
Dpanther, your photo is way oversized. The limit is 800x800 pixels.
Monkeyboab, what KD driver is this mysterious 14mm boost driver?
I am sorry about the picture size and this is my first post so I am trying to figure it out.
The driver in the mini mag is a 500 ma lux drive micro puck purchased from led supply it fits inside the mini mag body where the switch used to be along with some copper pieces. it is nearly the same size as the switch so the two batteries fit fine. I plan to make another tomorrow and take the pics to post.
For now I will put up some more shots hopefully the right size and pics of the parts,
These are the parts used in the project: one mini mag 2aa incan version, bits of copper, 500 ma micro puck, terralux click tail cap, 14 mm heat sink from KD, ssc p4, artic alumina thermal adhesive, and a reflector currently borrowed from a terralux kit but soon to be upgraded.
ry%3D400
The driver from KD is on the way to me, i'm also still waiting for some r5's, since i can't find the first ones i had.. ;) lost in my appartment :D
I need to have a look for the space with an xp-g, so i can't tell yet..
Instructions:first take the mini mag apart and remove the junk internal switch. Set that aside for now.
ry%3D400
Take the 14 mm heat sink and use a hacksaw to enlarge the holes so the wires can fit through them from the top of the mini mag body.
ry%3D400
Take the ssc p4 or other chosen led and flatten and trim the contacts with needle nose pliers.
ry%3D400
Now use Artic Alumina thermal adhesive to glue down the led with the contacts over the slots in the heat sink.
ry%3D400
Next take the micro puck driver and trim the wires to around an inch use a wire stripper to prep the wires.
ry%3D400
Then cut thin pieces of copper plate that will fit in the mini mag body about a third of tube for the negative contact that will be on top. the bottom positive contact can be bigger since no wires have to go beyond it. Use thermal adhesive to glue them to the driver.
The copper should stick out to the sides of the driver. Now solder the red wire to the bottom piece of copper so that it does not stick out below it and the negative black wire to the smaller piece of copper in the same way. Then fold the green and orange wire around each respective side and bend them so they point up they will need to stick out of the flashlight battery tube after the driver is inserted.
ry%3D400
ry%3D400
ry%3D400
ry%3D400
ry%3D400
Put the driver in the battery compartment with the green and orange wire and negative contact pointed to the top of the compartment. I used a permanent marker to push it to the top and hold it in place. make sure the green and orange wires stick out and the negative contact connects with the top of the flashlight body.
ry%3D400
ry%3D400
ry%3D400
Solder the green wire to the negative of the led and the orange wire to the positive. then use thermal adhesive to attach the heat sink to the flashlight body or do this step in reverse if you are more comfortable with that.
ry%3D400
Now modify the current reflector with a drill and sander or use one that you ordered. Insert 2 AA alkaline or NiMH rechargeable batteries and screw on the Terralux or other on off switch cap and you are finished.
ry%3D400
