PCC
I currently have four generations of 2AA Mini-Maglites in my posession so I decided to do a photo essay on them to show the differences between them all.
They are: early Mini-MagLite, later Mini-MagLite, Luxeon Mini-MagLED, and later Rebel Mini-MagLED. Note that there was an earlier version of the Rebel Mini-MagLED that is the same size and has the same configuration as the Luxeon Mini-MagLED but has the newer Rebel LED module and plastic mounting ring. I don't have one of those currently. I do not know when the different versions came out. The Luxeon Mini-MagLED is a single-mode light that draws about 400mA from two NiMH cells at 2.4V resting. The later Rebel Mini-MagLED is a multi-mode light that draws about 220mA from the same batteries on high, about 50mA on low, and has blinking and SOS modes, all obtained by turning the light on, off, and on again quickly. The newest Rebel Mini-MagLED is visibly brighter than the older Luxeon MagLED, despite drawing less power from the batteries.
On to the pictures:
Left to right in all of the picture: Mini-MagLite, Luxeon Mini-MagLED, and Rebel Mini-MagLED
You can see the height difference between the three shows the old incandescent Mini-MagLite being the shortest and the Luxeon/early Rebel Mini-MagLED are the tallest and the newest Rebel Mini-MagLED is right in the middle, length-wise. The old Mini-MagLite belongs to csshih.
Here are the pictures of the lights dismantled:
The business end of the three lights
The heads taken apart
The light engines removed from their hosts
The body tubes
The last photo shows the differences between the ways that Mag has used to make contact between the tail caps. The incandescent Mini-MagLite uses bare aluminum on the threads. The Luxeon Mini-MagLED uses an exposed contact ring that can be seen inside the battery tube past the threads. The latest Rebel Mini-MagLED has bare aluminum on the end of the body tube.
The different tail caps
The incandescent Mini-MagLite tail cap has bare aluminum threads. The Luxeon Mini-MagLED has two metal contacts and an oversized spring. The last tailcap is not a Rebel Mini-MagLED as it has bare aluminum thtreads while the correct one has anodized threads and a ring of bare aluminum at the point where it makes contact with the body of the light.
Here you can see the differences between the incandescent Mini-MagLite and the current Rebel Mini-MagLED tail cap with the springs removed
You can see the larger hole on the left tail cap that is drilled deeper than the Rebel version
The Luxeon and early Rebel Mini-MagLEDs have a longer body and a different tailcap that is not compatible with the earlier and later Mini-MagLites nor with the later Rebel Mini-MagLED. The Mini-MagLite tail caps can be used with the latest Rebel Mini-MagLED flashlights if you remove the anodizing from the area of the tail cap that makes contact with the bare aluminum at the end of the body of the light. The tail cap used on the latest Rebel Mini-MagLED can be used on the Mini-MagLite if you remove the anodizing from the end of the flashlight body. The longer tailcap of the Luxeon Mini-MagLED is not compatible with either short
tail cap lights.
I've found an earlier version of the Mini-MagLite. The bodies, heads, tailcaps, and reflectors are the same but the early tail cap spring and bulb retaining system are different:
Early system on the right, current version on the left.
It's interesting to note that the two different LED modules are actually interchangable. The Mini-MagLED bodies are essentially the same as are the head and reflectors. The early Rebel Mini-MagLED is essentially the same flashlight as the earlier Luxeon Mini-MagLED but with a new module and retaining ring.
I even installed the older Luxeon module into my Rebel 2D MagLED to see if it would work and it did.
Of particular interest to lots of folks here on CPF are modifying these little lights. Here are four lights that I've modified:
From left to right: black cut down Mini-MagLite (currently waiting for a sandwich), silver cut down Mini-MagLite (going to put a Nite-Ize 3-LED drop-in into this one), blue cut down Mini-MagLite with Nite-Ize 3-LED module that I built for my grand nephew, metallic blue Mini-MagLite with a Sandwich Shop Mad Max Plus, custom heatsink, XP-G, and Nite-Ize IQ tail cap that I built for my daughter.
Yeah, my grand nephew could be the world's youngest flashaholic!
The longer Luxeon Mini-MagLED tail cap can be modified to work with the other Mini-MagLite/MagLEDs if you have access to a mill or lathe
The middle one is modified to work with the Mini-MagLite
Anyone else have any Mini-MagLites or Mini-MagLEDs to show?
On to the pictures:
The body tubes
tail cap lights.
