Modamag's M2 Reflectors
Ms_SS
CA
We are trying to create a FAQ page for M2 Reflectors. What reflectors, bulbs and opening sizes are compatible? Please post and add specific bulb and hole size to the list.
Here is a list started by Modamag in January 2006.
Standard ream (opening) size = 0.310" / 7.87mm
Special 20x units with ream size = 0.520" / 13.21mm
=== Typical Bulbs Size ===
Welch Allen Lamps (S-Config) = 0.287" / 7.29mm (Compatible!)
- WA1111 / 1160 / 1166 / 1183 / 1185 / 1274 / 1331 ... etc
- Most high power lamps CPF uses
Pelican Big D (low output) = 0.300" / 7.62mm (Compatible!)
Pelican Big D (high output) = 0.320" / 7.62mm (Compatible only with special order)
Carley Lamps (T1 / TL1 ) = 0.135" / 3.43mm (Compatible!)
Carley Lamps (T1 / TL1 ) = 0.190" / 4.83mm (Compatible!)
WA/Solarc 10W HID = 0.500" / 12.7mm (Compatible only with special order)
OSRAM & Phillips GY6.35 = 0.425" / 10.80mm (Compatible only with special order)
ceramide says: Modamag's M2 Camless aluminum reflector to 0.625" fits both the current Malkoff Mag D drop-ins and his original Mag D mods and Mag C
litho: The .625" diameter opening will accomodate the Mag pedestal, just like the stock plastic Mag reflector. I'm not into LED's that much - I believe the .625" opening will work for most LED applications, definitely HID applications and Incandescent bulb applications as well.
