Modded my SL Argo HP (foto's)
bonhomme
belgium
Hello, a time ago i modded the argo HP with a luxI high dome instead of the side emitter : more trow and still plenty of sidespil , and no more artifacts .
Now, i have a few SSC P4-U emitters to play with!
So i swapped the luxI (emitter only) into a SSC P4-U on the headsink of the luxI. I also had to trim the back of the reflector to get the perfect focus.
WOW : the low setting with the SSC gives the same as the high setting with the luxI ! The high setting with the SSC (+-270mA consumtion on the 2 x cr123A batteries), gives me thesame amount of light like my QIII (modded with a badboy750 convertor,White Luxeon III 3W Emitter LXHL-PW09 UX1L ,IMS reflector and ultra clear lens) = 1300mA consumtion on 1 cr123A battery.
So : i am VERY happy with the result!
Greetings Marc
Argo Low (SSC P4 U-bin)
Argo High (SSC P4 U-bin)
QIII with LUXIII U-bin (badboy750mA)
QIII with SSC P4 U-bin (badboy750mA)
Left=QIII LuxIII U-bin (badboy750mA) Right=QIII SSC P4 U-bin (badboy750mA)
Left=QIII LuxIII U-bin (badboy750mA) Right=Argo Low (SSC P4 U-bin)
Left=QIII LuxIII U-bin (badboy750mA) Right=Argo High (SSC P4 U-bin)
Left=QIII SSC P4 U-bin (badboy750mA) Right=Argo Low (SSC P4 U-bin)
Left=QIII SSC P4 U-bin (badboy750mA) Right=Argo High (SSC P4 U-bin)
Re: Modded my SL Argo HP
wow!!! this is really great news... I ordered one of these, but wasn't sure if the regulator circuit would work properly with other LEDs... sounds like things are in range... I might have to give this a whirl..
i just can't understand why SL when developing a product doesn't see that using a normal LED will produce a much better beam... why the SE?
thanks for your post! pics would be great!
Added some foto's in first post.
Lights where 75cm of the wall (at 1meter the sidespill was a problem for my camera (only 2Mpixels)).
Hope it is a little helpfull.
Greetings Marc
Bought a lux meter:
QIII original: +-500lux
QIII SSC P4 U/BB750mA/UCL/IMS reflector : +-1200lux
Argo HP SSC P4 U low : +-400lux
Argo HP SSC P4 U high : +-1200lux
dang..... you have a killer headlamp.... thank you very much for those pictures... hopefully the SSC P4 U bin's will become
