mitchell300
I have been looking to mod my inova T4 for some time now.
The easy part of the taking apart it getting the switch out its much the same as a maglite switch but much higher quality. the good thing with removing the switch assembly is that it gives you an area to put a pole though to generate much more leverage when holding the head in a vice.
I have been reading a few posts and it has been mentioned that the head held on by red loctite. Red loctite breaks down with heat.
According to loctites FAQ's you can loosen threads with loctite by heating and then twisting.
my only worry is that it mentions getting the area quite hot, do you think that would be do-able as long as the battery switch assembly etc... was removed?
Thanks,
Thanks,
