ICUDoc
I know this has been done before but a few comments of my own:
-Despite opening a U2 head before with a little heat and a lot of force from two locking-pliers and rawhide padding, I COULDN'T do it on my new U2 head.
So I put it in the freezer for 30 mins then added a few drops of acetone to the groove over the threads and it came free (with a lot of force!). The grnamin YouTube video is a must-see.
-The LED sits between two grooved projections on an anodized aluminium heat sink that is gently stuck to the electronics module with what looks like Arctic Silver 5. The old Lux V fell off this when desoldered.
-Test fitting showed that the P4 abuts the back of the reflector and so a small amount was knocked off the reflector with a Dremel to bring the LED closer to focus. The material comes off the extra aluminium backing the reflector, not off the silvered area at all.Edit- the flat back of the reflector also pushes down on the solder on the LED contacts if you heap it up at all, so keep it flat.
-I still needed more room so I took away a small amount of material from under the old LED (between the heatsink projections).
-The SSC fits perfectly in that space. Arctic Silver epoxied in place.
The output is a little more throwy than the stock, but seems to have more total output than even my WXOS-modded unit. Beamshots to appear on icudoc.com tonight. Runs on one 18650 noticeably brighter than the WXOS on two CR123As. Edit- some mod photos on the website. Beamshots laterish.
-I have done 10 or so mods- this is the hardest because of difficulty opening the head. Otherwise the Dremeling is slow and steady not ultra-high precision, and the rest is easy to get good alignment. I am pleased with the outcome.
