Modlite OKW mod
ike1985
Does anyone know what LED is inside the OKW? I wonder if this light could be pushed to absurd levels if modded with an SBT90 and which version would be better for the swap; 18650 or 18350 version? I like the 18350 because its lighter and having an extra weight on the end of the gun sucks.
This is interesting, thank you.
The SB90 G2 looks like it draws about 16 amps at full power....
https://www.candlepowerforums.com/v...-Thrower-LED&p=5367708&viewfull=1#post5367708
I doubt that you'll find a 18350 that will deliver that much current, Aspire made one rated at 15A but only really delivered 10A. High current INR 18650s are available but probably have a realistic capacity of 2000 - 2500 mah, which will give you about 10 minutes of runtime.
I wonder if a Malkoff Bodyguard head would fit your body tube?
P
Both the OKW (and the PLHv2) LED's look identical to the XP-L HI (domeless). I'm not a modder (I just do Legos), so I can't answer the rest of your question.
