lexina
- Joined
- Jul 3, 2005
- Messages
- 782
I have been trying to figure out how to make my MagC switch momentary so that I can run a D2Dim or a bflex. There's an excellent guide here:
http://www.candlepowerforums.com/vb/showthread.php?t=90912
but it only covers the MagD switch.
I didn't have to do the first part (i.e. removing the ribs so that the switch doesn't catch) because I actually had a malfunctioning switch which was already momentary (and which I nearly threw away because of that...lol).
What I need advice on is the wiring between the switch and the bflex. I have drilled 4 holes and inserted 2 wires as shown in the photo below:
This is what I plan to do:-
1. solder the red (wire 1) and the black (wire 2) wires to the bottom contact place where the positive of the cell touches [Edit: this is incorrect - please see posts below]
2. solder a wire (wire 3) to the top contact plate
3. solder a wire (wire 4) to the negative ground strap
4. solder wire 1 to the IN+ of the bflex
5. solder solder wire 4 to the In- of the bflex
6. solder wires 2 and 3 to SWA and SWB of the bflex (Advice needed: does it matter which goes to which?)
7. solder wires from the bflex to the led.
Is my wiring correct and will the above work? The D switch mod had some cutting of the switch contact plates - I am not sure if that would be required here.
Thanks for any help,
lexina
lexina
