KrisP
Hi,
I have a 1C Maglite light with a DX 5-mode driver with linear regs on it. This is not the best driver and once the voltage gets down to 3.8V (about 2Ah of the 3.3Ah battery is used) it starts to drop the output voltage, therefore dropping the current.
What i'm looking for is the most efficient driver for a single li-ion to run an LED at 3.5v @ 1A but with multi-modes. The Flupic seems quite good but i'm unsure what the maximum current will be and at $35+post it's quite expensive compared to the $3 DX driver. Even with the Flupic, once the voltage drops below 3.5v or so, the LED is going to stop drawing 1A. Is the Flupic the most efficient multi-mode driver for this application? Or is there a boost/buck driver that has multi-modes? I couldn't find one in the Driver board list / regulator board list. thread.
Thanks
Thanks
