Can anyone explain to me the effect of a lower or higher Correlated Colour Temperature as well as a high Colour Rendering Index on picking out markings made with red gloss paint? Would 4,000 Kelvin LED "favour" the red more than 6,000 Kelvin, or the other way around? Is a high CRI more significant in this respect than the CCT?
The specific application would be picking out the trail markings on mountain routes. In Switzerland, for example, these markings consist of a red stripe sandwiched between two white stripes. In South Tyrol (Italy) they use the opposite, i.e. a white stripe sandwiched between two red ones. In various other alpine regions a single red and white stripe are to be found, but in Norway they use a red letter T without any white. I'm reluctant to post photos for which I don't have copyright, but if you Google "Den Norske Turistforening" and then select "Images", you'll see examples of the Norwegian "T" markers and if you likewise Google "Bergweg Markierungen" > "Images" there are loads of Swiss and other mountain trail markings to be seen.
I need a combination of a headlamp with moderate output and a handlamp with a fairly powerful output as a short-time booster to scan the surroundings (for markers) out to a maximum range of about 150 meters. It's important that both lamps can pick out the red as well as possible.
I usually keep my headlamp on low power for reading map, compass and GPS and for searching for markings out to about 35 meters. The booster handlamp is used in short bursts in order to save the batteries of the headlamp.
I'm not looking for a recommendation on specific lamp models, but rather some pointers as to what properties to look for, given the above requirements.
Thanks in advance for any relevant advice.
