If anyone's looking for a straightforward, effective method for soldering & mounting Luxeon Rebels, this method has worked well for me (after experimentation with a few other methods):
Take one rebel:
Place it somewhere upside down so that it won't move around too much when you're soldering it:
Coat the copper contacts on the rebel with solder:
Place the rebel with the soldered contacts aligned over the copper pads of the
rebel star. Pre-heat stove hotplate to medium-high or thereabouts and place the star on the hotplate with tweezers or needle-nose pliers:
Take the star off the hotplate as soon as you see the solder melting onto the star's copper pads. You want the hotplate to be at a temperature that will melt the solder in 5-15 seconds. Too much time or too much heat can damage the LED or the circuit board. You might want to be especially careful with the higher spec'd rebels - I only used red & blue ones for this project (they suffered no heat damage), but others on the forum are suggesting the 100 lumen white rebels are quite sensitive to heat.
I mounted the stars to a chunk of aluminum using
heat conductive pads as the thermal interface. Works well, although that aluminum sure gets hot!
Note, no affiliation with led-tech.de, that's just who I happened to get the gear from.
