Johnyjackpot
Hi, I looked for an answer to this question and couldn't find.
I purchased a Innova 3320 multimeter which has a battery load test function. I use it to check the state of charge on 3.7 volt li-ion's. I have read on this forum that I should load the battery with a 10 ohm resistor when testing with a multimeter.
http://www.candlepowerforums.com/vb/showthread.php?t=214963
Does the battery load test function act as a resistor or do I still need one? If so which voltage should I use? (1.5-6-9-12 ) Thanks for help, John
