Divine & Kaichu Dento:The biggest mistake you will ever make with any set of LED flashlights is to go "white wall hunting" and turn on two lights against one another; things that look perfectly white by themselves "magically" turn into something markedly different when looked at together. This is the nature of LEDs and variations occur across of reel of LEDs of identical bin. :shrug:
I still maintain that the Mako produces the best beam color that I, personally, have seen in a flashlight that uses 5mm LEDs. Judged on its own merits, I think that you will be pleased with what you see. If you start going white wall hunting and comparing it to power LEDs and X number of other lights it wasn't designed to "compete" with, then your mileage may very likely vary. :shrug: Point being, the Mako is a decent little light that does what it was designed to do well, and I've tried to make it very clear as to what that is, and what it's capable of. Whether or not it does what you want it to do is another story entirely, and up to you to decide. :nana:
seery: I do not like hair-trigger level spacing; I've owned too many lights done as such that I end up unintentionally blinding myself with due to insufficient level spacing. Mode spacing on lights that I make will always be sufficient to not accidentally activate into a higher mode than you wanted to be in.
-Enrique
