M52 POWER!
- Joined
- Feb 8, 2009
- Messages
- 27
I own a 05 BMW M3 and one of the cool things about it is the rear lights are all LED's except for the reverse lights! I thought it would be cool and fun to make some LED backup lights so everything would be LED :)
I found a site selling LED bulbs and ordered them. Once I got them I was disappointed with their output and quality. Shortly after I discovered DX and then CPF forums. I read and read and set out to make a PROPER LED backup light ;)
I ordered some XP-G R5 drop in P60 pills and converted them to the car style plug in adapter and the result is awesome!
Left aftermarket "cluster" LED, Right XP-G
Below is comparison of the XP-G and the aftermarket LED bulb! :eek: I think you can guess which is which :rolleyes:
And both together!!
Quite a dramatic difference! :thumbsup: I'll have night time shots later tonight.
Also I measured amperage draw of the XP-G and at 12 volts it was pulling around 500ma. So that should be 6 watts right? How do I calculate current at the emitter after the board?
I think the next step is to get a proper buck driver that will run the XP-G's @ 1400-1500ma.
-Chris
And both together!!
-Chris
