I wanted a flashlight that could be turned from the off position directly to high OR low with a thumb operated switch near the head of the flashlight as opposed to a twisty or tail-cap pushbutton. It had to have a CREE XR-E and use AA batteries and have a glow in the dark part. So, here it is..... and it is one UGLY flashlight. I am, after all, just a salesman.
I took the body of a cheap 3-AA 49 LED Ebay flashlight, and removed the head. I installed a rocker switch, and hooked up to the high-setting through a resistor to drive the CREE at 1000 ma at full battery power (2 hours battery life). The low setting (bigger resistor) is 100 ma (20 hours battery life). I mounted the CREE LED on a steel tailcap from another junk flashlight, and screwed that tailcap directly onto the Ebay light. I used JB-weld on to house the LED reflector using the head from a third cheap Wal-Mart flashlight. Next I filled in the hollow area on the tail cap using a $3 bottle of glow in the dark fabric paint. Although it's my new EDC, I am embarrassed to be seen with it. Good thing I only use it in the dark.
Total cost: $48
Brightness: About 30% brighter than my M3 on high
(only my D-mini is brighter, and not by much).
If anyone knows of an off-the-shelf light that meets my qualifications from above, I will gladly replace this eyesore!
Front w/ rocker switch:
Glow in the dark tailcap:
Total cost: $48
