My LF5XT stops working from time to time. It just shuts down and refuses to start again if i don't put a new battery in it. And i tried it whit a cheap AA Alkaline and whit that the 100% was dimmer then the 50%, is that normal?
The battery protection circuit should just make the light start blinking? It newer starts blinking. I hadn't used it for more than a few minutes (total time) before it happened the first time whit my brand new AW 14500. When taking out the battery it was a bit hot 40-45 degrees Celsius perhaps.
I had forgotten my charger at home so I had to use what was available (alkaline).
Alexi, both the head's innards and the switch in the tailcap are held in position by rings. As somebody here has already reported a few of these rings were loose or just not well tightened.
I suggest that you check yours with the help of needle nose pliers or even a shaped paper clip. If these things become loose the electrical contact is most probably affected and as a consequence also the light's behavior.
