tomatocanlite
- Joined
- Mar 23, 2008
- Messages
- 1
Copy of Dinotte
I can't really help it but the Dinotte is such a well designed light and I want a flood to compliment it
Part Lists
1 X Q5 on Star
1 X 25 degree optic for Lux III
1 X Taskled Nflex
1 X Short Cable
1 X 6mm Gromet
6060 T6 Aluminum Rod
Delrin Rod Black
10 X M2 Screws
Artic Silver Thermal Paste
I decided to cut slot onto the body for better heat dissipation. Optic and star sit onto the "bore" I made on the front. Black Delrin Brezel hole optoc in place and Star LED is further secure against the body by 2 X M2 Screw and with Thermal Paste.
Nflex slot nicely into the black via 2 slots I milled on the inside diameter.
Cable thru gromet provide some protection during wet weather.
I cut a little curve at the bottom for the handlebar but I got no idea how it was done so it end up "straight". Can any kind machinist give me some pointer?
Notice the "gap" on the front brezel?? It is meant for a silicon gasket (in the making) for shielding against wet weather.
Some stuffs I picked up at an electronic store. The SMD switch, I intended to make a touch switch with it. The rubber tube thingly is meant to slide over the DC connector for weather shielding.
Some beam shots.
200L Spot. Distance of light to wall is 2m.
Camera setting is 1/20sec, F4, ISO 400.
My "tomato can" light - Flood. Same camera settings.
Suggestions anyone??
Part Lists
1 X Q5 on Star
1 X Taskled Nflex
1 X Short Cable
1 X 6mm Gromet
Delrin Rod Black
10 X M2 Screws
Some beam shots.
