My Shop Equipment
Tom Anderson
Manchester, PA
Some folks have asked about the equipment I use. It's a collection of machines and gear that I've accumulated over many years. There's nothing really fancy - none of it is CNC controlled (unless you think CNC means "Crank 'N Cut!" :D)
Some of these photos are a few years old, but my shop looks pretty much the same now. (Well, maybe not as clean! ;) )
This is my little 2-hp bench mill/drill. I've added a number of gizmos to it (DRO, variable speed drive, rotary table, etc.).
My 12" x 36" gap bed lathe. (I don't remove the gap bed, so it's really more of a 9" x 36" lathe.) Again, I've added a few gizmos to make life a little easier (DRO, 5C closer)
I've actually added a Sjogren 5C chuck to my late since the above photo was taken. It makes accurate turning a lot better.
My 20+ year old drill press and a home-made 18-ton hydraulic press.
My bandsaws. The front one is for metal and the one in the back is used to cut wood and other soft materials.
My Wilton 2" x 72" grinder. I've made a few modifications to this, including a variable speed DC drive. Behind it is a 6" x 48"/12" disc combination sander.
A slow speed (90 RPM) horizontal disc sander. (Made from various bits and pieces.)
My little surface grinder.
A small 1/2-HP buffer.
Belts for the Wilton.
My air compressor setup. I got tired of burning up motors on the one on the right, so it just serves as an expansion tank. Now I have 140 gallons of air at 120 psi. :D
My bench top bead blast unit. It has a number of coalescing filters and a drier attached to it.
My main dust collection unit. I also have two other small filtration units.
An ultrasonic cleaner.
My anodizing equipment. (I call it "the Tower of Power" :D )
My parts queue bench, made from Hastelloy for when I work with acid. (Old photo showing folder blades that I finished years ago. I normally didn't make so many of one model knife at a time, but these were for a dealer.) I stopped making knives a few years ago.
... and, my main workbench.
That's it!
BTW: All this stuff is located in my basement.
Nice shop :thumbsup:
The Wilton Square Wheel is an awesome grinder. Looks like you have a 3M structured abrasive belt mounted in the photo ... they work very well.
Similar to what I have - mine is 180 gallons (3 tanks at 60g each) plus at least 20 gallons more in piping the shop end to end.
Very nice! Hope you don't ever want to move! :poke:
Me too! I've been in the same house for 34 years. ;)
I really like my Square Wheel grinder. I did a few modifications to it over the years ("tweaking" it to suit the tasks at hand). The biggest improvement was adding the variable speed drive.
Those Trizact® belts are nice for finishing and they last a long time. I use the 3M ceramic Cubitron® and Regalite® belts for heavier grinding. Titanium quickly wears out everything else I've tried.
I agree that you can never have enough air in the shop! :)
Tom, can't wait to see some flashlights created by you!
Ya got to post the pic of your Ti stock collection too! :naughty: :poke:
Nice shop.
Speaking or compressed air, at the CC Theatre I work at while attending school there we have compressor power that would blow you away.
What we have is insane and is illogical for us, but it's nice.
50HP rotary screw compressor (IR)
250gallon air receiver
Large Dryer
We use pneumatic staplers and nail guns.
Occasionally a impact wrench. That's it.
Not to mention the copper piping with legs around the shop.
Seriously insane.
Tom it looks like we have basically the same mill/drill, Mine is the Rong Fu RF-31, looks just like yours except the color.
I am thinking about putting a 3 axis DRO on it and I looks like you have done it to yours. Is there any possibility of pictures showing how your scales are mounted?
Particularly the Z axis.
Thanks.
Awesome shop Tom!
Thank you! :wave:
I think I'm going to leave the making of custom flashlights to the professionals. :D
My titanium stock is always changing. Here's the bar stock I had a few weeks while back. (I've used a bit added a bit since then.)
The tubing is stored in another part of the shop. I just got a few more pieces this morning.
1" OD, heavy wall (.200") seamless
I bought this to make a few of my special "Nuke" Titanium Canes. (They're kind of rare - I don't even have them listed on my website right now.)
Nice shop.
Large Dryer
Seriously insane.
Sounds like overkill. I love overkill!!! :crackup:
Thanks.
I made all the brackets myself. The body of the Z axis spar is mounted through two of the holes where the nameplate was mounted. The reader has a steel bracket I made which is then fastened to a titanium strap that is mounted to the quill casting. I had to drill and tap the quill casting for the mounting screws, but it was easy to do. (Sorry, it's been a while since I did this. Needed to jog the memory.)
Anyhow, I think Grizzly now has complete 3-axis DRO kits for this size mill, including the brackets.
+1
My Burr King 482 became much more useful with the larger 3hp motor & VFD control. Same with the Delta 6" belt - 12" disc sander, the drill press, and the wire wheel machine. Lots of manufacturers offer a variable speed option but want an arm & a leg for a drive that costs not very much.
Where do you find the Ti mechanical tubing?
Most of us can only dream of such space and tools :)
And the items he produces with them! At least that part can be a reality! There's not one item I have seen of Tom's that I haven't drooled over many times. It's been a very long time where I have felt this way about someone's work/products that I have seen. Tom's Twister pens are stunning!
Ok, ok, I'll shut up & go wipe the drool off my face now.
As a backyard mechanic with mainly hand tools I have to say I'm really impressed with your compressor and your dust collection system.Oh-and all the titanium also.
The rest is just eye candy to me.Mouth watering eye candy.:whistle:.
Thanks, everyone! :wave:
+1
Being able to dial-in the exact speed makes it easier to get a good surface finish and saves your tooling when working with difficult to machine materials.
I have several suppliers that have been kind enough to let me know whenever they come across some. :)
I use the heavy wall stuff to make the shafts on these:
There are 3 tritium vials in the head:
