morrisman1
- Joined
- Jan 27, 2009
- Messages
- 6
hi, im new here and probably wont be around much at all, just thought i would share my creation with some like-minded people
i wanted to build a grunty LED light for my bike, so i thought i would use the CREE XR-E as my platform as i was pleased with how it performs in my fenix T1.
One is never enough so i went with three of them. after some research and thinking, i decided to run with the LEDs in series, off a 12v/7Ah Lead acid battery (im cheap and cant afford a Li-Ion pack, plus they aren't as easy to get here in New Zealand) there is a 1.5 ohm resistor and a 5.6 ohm resistor in the circuit and i can decide what one i will direct the current through so theres two brightness levels.
on the 2.7 ohm resistor the LEDs run at approximately 80% of their rated capacity.
as you can tell the casing is an absolute work of art, there's some serious precision engineering happening there! I have put the fan in to keep the resistors and the LEDs cool, i found that the LEDs can get very hot and just to keep things a bit a little more in the safe range i have a 40mm computer fan wired in to keep the air moving. The lens are 2x 25° and 1x 10°
http://nz.youtube.com/watch?v=sKf2vBw937I
heres a pic of inside:
the insides have changed slightly since that photo was taken
your comments are most welcome!
