This was a classic desert moment: very long day at work, nice warm commute home (down to 105 F) dinner and a couple of malts put away... time for a swim! It was well after dark and I was wearing the Zebralight H30. This is not my normal swim-light, but I was only going for a quick dip. Besides I was working on my third drink, so the offices of logic and restraint were already closed. At first I was happy that the nice uniform flood beam worked great under water. Then things got rather goofy. You know what the Z-light does when you hold down the button, cycling through the 3 stages at just under 1 second intervals? Well, it does the same thing when it floods, except you don't have to hold down the button. Damn, another light that can't take 4ft of depth for 30 seconds.
Don't get me wrong, I really like the Zebra. It is one of the most useful lights that I own. I hope that it still is when it dries out inside.
But here is the frustrating part: with all of the LED lights that I have laying around, the only one that can go into the pool reliably time after time is a first gen Inova X5. I keep trying to upgrade, but everything from the Inova gen-2 onward has leaked. Obviously I haven't tried everything, but some well respected names have failed me in the water (including Surefire and Streamlight). It is not the o-rings, but the rubber switch cover that seems to be the problem. This is where the simple 2-cylinder concept of the original Innova proves its worth. It even starts out clamped down, so you can't turn it on in the wrong direction under water and flood the case.
So I am still searching. Dive lights are too ponderous for casual use. Ideally it should be wearable, either as a headlamp, or on a neck cord. Flood pattern preferred, but not the annoying >180 degree pattern of the H50. Suggestions?
gerG
edit: fixed some crummy spelling
gerG
