Exit32
- Joined
- Oct 28, 2004
- Messages
- 65
I bought this flashlight about twenty years ago, and I've always wanted to know more about its origin and its manufacturer. It's an incandescent light comprised of a simple anodized, knurled aluminum tube with a bulb-and-reflector assembly threaded into one end and a switch assembly threaded into the other end. There are no o-rings, so obviously it's not waterproof.
This flashlight accommodates two C cells. It appears to have a pre-focused bulb like those used in cheap AA penlights. The reflector is made from uncoated aluminum, and it's quite dull and ineffective.
The most interesting part is the tailcap with integrated switch. It uses an aluminum stud, threaded on one end and knurled on the other, to push against a piece of spring steel that makes contact with the negative side of the rear battery. To turn on the light, you twist the stud clockwise until it's tight; to turn off the light, you twist the stud counterclockwise until the stud loosens enough to break contact between the spring steel and the battery.
The tailcap has lettering that indicates that this light was manufactured by the Princeton Carriage Co. of New Brunswick, NJ. It also claims there's a patent pending on this design.
I haven't been able to find any information about this flashlight manufacturer. I'd also like to know how old this light is and would appreciate any information from the many flashlight experts here. See photos below:
