DM51
Re: Navy Dive Light
Thanks KevinL and missionaryman, yes, I think I'll stick with my plan to use AW "C" Li-Ions. The extra run-time will be valuable, and changing cells between dives will be easier too.
The PR bi-pin adapter has arrived. It is a very nice piece (thanks to FM, and especially to jimjones3630). It is ~3 mm bigger diameter than the stock PAJ bulb, as you can see in these pics (WA 1185 already fitted for illustration purposes):
The bulb holder is a big chunk of steel, and boring it out the extra 3 mm to take the bi-pin adapter will be pretty simple. This will not be an irreversible mod, as the stock bulb will still be usable in the larger hole with a thin steel washer acting as a flange.
Looking at the +ve bulb contact spring assembly, it doesn't look too special. There is probably some unnecessary resistance there, and I may have to think of some way to improve it.
