Need a floody light
crackerkorean
It seems most people go for a good hot spot and throw.
For my application (mountain biking) I need a goof light with a bit of flood to mount on my handle bars.
I used a 1watt ROV and it did ok the spill was nice but I would like the spill area to be a little brigther.
I am going to use my 3w ROV as a helmet light (where a spot is good) but need some additional light.
I am looking for suggestion from DX or kai since I am in the process of building my own triple seouls. I just need something to work until I am done with those.
I asked about a good light in the cycling forum but no answers were given.
thanks as always
For now under 30 bucks since I will be finishing my bar mounted light. Its going to have 2 x 15 degree lenses with 1x 25 degree.
The zebra light is a bit too floody. I have been looking through posts and can only find beamshots of a meter a way from the wall or so. I need one thats 2-5 meters.
I have tried several flashlights on handlebars in addition to and instead of a Princeton Tec Switchback 3 bicycle light.
The lights that have worked out well are:
Huntlight FT-01XSE (Cree, 18650, good beam pattern, multiple levels + strobe)
Rexlight 2.0 (AA, good runtime, good beam, same levels as Huntlight, remembers last mode)
Not so well:
Fenix P1D-CE (runtime too short, does not work well with rechargeables)
AmiLite Neo T5 (good beam but does not provide adequate runtime, does not work with rechargeables)
Jetbeam C-LE 1.0 (runtime too short)
LED Logic Striker-VG (not enough flood, heavy)
The multi-LED lights are the up and coming thing for bikes, no question. I was considering a ElektroLumens FireLion be decided to go with a Dinotte 600L instead. My PT3 has a great beam pattern as well. I would definitely look for a 18650 battery -- otherwise run time and operating cost will be problems.
My T5 has never been fed a primary! All I use are AWs protected RCR123s @ 3.7v and it works great! I sometimes swap the body to the T3 if I want a more compact twisty and it works great then as well! If I recall William Lafferty also runs the T5 head/T3 body without an issue.
Hope you don't mind me tellin' all your secrets Bill :wave:
The T5 looks like it would have a great beam pattern but its a bit out of my budget.
I am just looking for a temp fix till I finish my DIY bike light.
The runtime with the AW RCR123's on high is about 20 minutes. Your rides may be a lot shorter than mine. I really need 4 hours for a good weekend road ride and a minimum of 80 minutes or so for one day's worth of commuting.
