D
DirtyDaveMO
- Joined
- Sep 28, 2018
- Messages
- 5
I mow my 4 acre yard at night when it is cooler outside and I have time. It takes me less than 3 hours. I have some LED lights on my Scag mower but I also wear a headlamp with earbuds to listen to my audiobooks and then cover my ears with ear muffs. I also wear a hat to keep the dirt and bugs out of the little hair that I have left. I have about 3 different headlamps that I use depending on which one I can find. They have a bigger head/light with 2- 18650 batteries on the rear of the band.
I am looking to upgrade my headlamp. I like to have a flood for about 50 yards when mowing most of the time but I also like to have the ability to use a spot for 300 yards if I see a deer or other animal while mowing. I have to remove the batteries and put them in my charger after each mow. I have a headlamp that has a good spot but poor flood and one that had good flood but no spot.
If I could find a headlamp that is rechargeable and will have 3 hours run time and have the spot and flood functions I would spend about $150 if I need to. I would also be willing to build one if I need to. I let you know about my setup incase there are other ideas someone has. Maybe have two headlamps with one connected to my hat or something like that. I am open to suggestions. I think the built-in charging is my number one requirement. This is like what I have now.
Thanks again, Dave
Thanks again, Dave
