Hi, I'm new to the forums and to the world of modern flashlights, and I need advice for a particular usage. I've been lurking for a week or so and have done a lot of searches, and I think I've at least narrowed down the choices, but can use some help now.
Usage: I need a flash that I can put in a pocket and that will still have a long throw. I need it for finding my horses in the pasture. So I need something that will allow me to see if my horses are safe, and standing up, at about 175 yards. So I don't need much definition at that point (it's not like I'm trying to identify them!) I just need to see them; thus the beam doesn't need to light up much area.
Other requirements:
1. I want to be able to carry it for short periods of time in a pocket. Typically I have cargo type/tactical pants or shorts on, so I have deeper pockets, but I don't want a very big head on the flash. I think something under 40 mm would be good.
2. I want the on/off switch to be on the end cap, with a momentary on with a single push. (I need to be able to turn the light on with one hand, wearing gloves, both momentarily and full on)
3.[FONT="] [/FONT]I want to be able to use rechargeables, preferably both 16340s and an 18650.
4. I'd like to be within shouting distance of $100.
I am not too worried about run time; this light is for short use only.
From the forums I've identified the following possibilities:
Jetbeam RRT-2
Olight T20 Tactical
Olight M20
Fenix TK10, TK11, TK12 (I can't really understand the difference between them)
Any thoughts/suggestions as to which of these (or others) will fit the bill?
Separately ( and I do realize this should be in the other forum) can someone quickly let me know if I get the same output throw from one 18650 as I do from two 123s? On the reviews the lumens output seems the same, but is that possible with 3.7 volts vs 6 volts? Put another way, why use 123's instead of 18650s?
Thank you all.
Other requirements:
Jetbeam RRT-2
Olight T20 Tactical
Olight M20
Thank you all.
