need help finding some mr11 bulbs
turbodog
central time
Any idea where I can find these?
mr11 bulb
glass lens attached
4 volt
spot faceted reflector
flood faceted reflector
15 watt
lifespan of at least 50 hours
Thanks!
Echo63
Perth - West Australia
do you mean M11 lamp assembly ?
for the pelican Products M11 Blacknight ?
if that is the lamp you need you should be able to get them from pelican products themselves or any shop that sells thier products.
gerald
Central Texas
Use google and search for mr11, mr8, and mr16 lamps. You'll find quite a few. No 4 volt, though. 6 and 12 volt are about your best low voltage choices. These lamps are also very easy to overvolt and get a bright white light with great lamp life.
