I have just recently entered the world of bright flashlights, beginning with an LED Lenser I bought to help find our dog (at 2:00 am, a small light just doesn't help very much with finding him when he wanders away outdoors.)
While walking through Walgreens, I saw some small LED lights that, to most people, would be considered "bright." Of course, I bought one, thinking I would modify it.
They are made of metal (or at least seem to be, the electricity is actually conducted through the body.) They consist of three parts (the light head, a body tube, and the rear switch,) plus an inner battery container that takes three AAAs. It is roughly a 3.75" length, 1" diameter cylinder. Currently, there are 9 white LEDs in the head, giving it great flood (but a low lumen count.)
Looking on DigiKey, I found plenty of high-power LED modules, many (if no most) of which will fit in the head (which is just over 1" in diameter.) I also found 2000mah (not sure if the abbreviation's right -- milliamp-hour) NiMH batteries that are the same size as AAAs (but they're solder-tab.) I was not able to locate a maximum current capability for them. Of course, to drive most high-power LEDs, I would need a voltage boost converter. I could either build my own circuit or use an LED driver, but a driver may be a better idea. Unfortunately, it would have to be under an inch in diameter and about (this is a rough estimate) 3/4" in height (or fit in a cylinder that size.)
I know that with high-power LEDs, you need good thermal management. I can use the body as a heatsink, right? I believe it is aluminum. I am trying to get the highest brightness (highest luminous flux) possible, but it must be able to continuously run until the batteries are drained with my hand on the outside.
I have not been able to locate any good information on this -- so I came here for help. Can you please help me pick an LED and driver to build this flashlight with? I do not wish to buy a stock EDC light (I did recently see a 900 lumen one here, however,) and am doing this as a project in my electronics class (high school.)
Thank you for your help.
