Need help with custom flashlight!
motosk8er2
Hello all, i have ordered the following items. I am wanting to know if the cree MC-E will fit in that host, and what optics would be required if any? Also is the driver listed a decent one that will work with this setup? Will the MC-E handle 1000ma or should i stay on the safe side with 700ma? If so what are some good drivers that will work with this setup? I want to use 1 18650 battery. With this i am trying to accomplish a verry verry bright light, long throw, narrow beam(spot), and on a cheap budget. Thanks a bunch!
http://www.dealextreme.com/details.dx/sku.16145
http://www.dealextreme.com/details.dx/sku.7426
http://www.dealextreme.com/details.dx/sku.15687
An MC-E can handle 700mA per die, so 750x4=2800 mA total.
With an MC-E you will not get a narrow hotspot and much throw with such a reflector. It will be very floody, maybe with a quite pronounced donut hole.
Wow, thank you so much. I thought the hole diode took 700mA, i didnt know it was for each die!
The setup will work. However, you could also buy the dx mc-e p60 pill and file it a bit and if you're lucky it will screw right into the threads of the body.
and yes, the mc-e, if driven at 4p is rated to 2.8A, so 700mA per die.
