Need help with first LED light project.
Reef Tank Lighting
Hello Everyone,
I am in the coral reef aquarium hobby. For this type of aquarium we need massive amounts of light to maintain the photosynthetic corals that depend on it to stay alive.
The project I want to try out is a smaller and simpler version of a very expensive LED fixture currently available. The tank this will be lighting is very small at only 3 gallons. The appx dimensions are 11 L x 8 W x 8 H.
The leds I have chosen are about 4-6 cool white Seoul Z-Power P4s, and 2-3 Blues. The light spectrum I need is around the 10K-15K range which is why I need the blues.
Also I have an $80 max budget for this project not including shipping. The tank it will be applied to is entered into a small contest on my reef forum and the amount of modifications is limited by dollar amount.
Here are my problems. First of all I cant find the leds at a decent price. I had a very bad experience with deal extreme. Does anyone know another place?
Second, how much current should I give these? I know they can handle 1000ma but only for a few seconds without a heatsink which I dont even know where to begin obtaining. These need to last at least a year, but at the same time give off as much light as possible.
Third, any recommendations on lenses?
Fourth, I was thinking of using an AC led driver, or maybe just a cheap wall wort type ac/dc converter. What would you recommend for my application?
Lastly, I have never done a project like this before. Are there any special wiring I need to do other than what would be done on a standard led?
Thanks in advance!
Steve
I don't know where to get blue SSCs, but you don't need lenses, any type of aluminum or copper channel, tube or sheet will do as a heatsink. Sheet will be the best (most surface area for least $). Thermal epoxy the LEDs to the heatsink. For drivers, you'll want a pair of
ld-mdu9-sc-3570.php
, each running four LEDs in series. That MicroDriver will run the emitters at 700mA, which I consider a good upper level for fixed lighting. Above it, you don't get very much more light but you do get a lot more heat.
