mrmike
I built an ROP with 6 Sub-C batteries (Elite 4500s in a stick).
It's in a 4D Mag with a 5Mega MOP reflector and a glass lens. I used the light all of ten minutes total (over several times testing it out), saw the reflector fogging up, took the head apart, and discovered this:
I took the bulb out and saw some of the plastic Mag post had melted:
I'm guessing the white stuff is some sort of thermal compound that surrounds the bulb in it's base:
I got a KIU BiPin socket, as I don't want to deal with this happening again.
I was wondering if someone could suggest a bulb that would give me the same output as an ROP. I know with the socket I can use other battery options with higher voltage bulbs... but the 6 Elite 4500 cells in a stick cost a good $60 with shipping, and I hate to waste a battery that has at most ten minutes of use on it. I don't really care if I can't get Mag85 brightness at 7.2 volts, I just want to salvage this light (and be rid of the melting plastic problem).
Any suggestions will be much appreciated... :thinking:
