Need some machining done
marinemaster
Atlanta, GA
Hi,
I need some machining done. Basically I need 2x sleeves made of either, Steel or AL or Copper.
Currently I have one of the the sleeves, but I need the second.
The first is of Copper material I believe.
I need to have both sleeves the same material.
The shorter one is 19mm long.
The longer one which I don’t have, I have measured it needs to be 28 mm long.
Is 8 mm outside diameter and 6.4 mm inside, so these dimensions are same for both.
So I need two of them one 19mm and the other 28mm long.
Photobucket has been down but pics should be here.
Copy and paste if the above does not work.
http://i568.photobucket.com/albums/ss128/mm888/sleeve.jpg
I have a pic, PM me and I will send it to you.
I am in USA
Thanks,
Chris
The first thig you will get is "what tolerance are you are looking for".
This may actually work, when I get home ill measure the screws outside diameter again, I think the second may be a good fit.
Ill report back. Thanks much for the link.
Lowe's has a specialty hardware section where they have small sleeves like this as well.
Received yesterday, fits perfect. Thank you very much for the advice.
I did check Lowe's some time back, but I did not find the correct size.
