Need switch for flash light.
brisco
I need a switch that does the following
" Click once - on A, Click again - off A on B, click again OFF ALL." Anyone have anything like this? It needs to be 12mm X 12mm pcb mount and name is OMTEN Part number is PBS1203T9. Having trouble finding a supplier.
Please dont yell at me if it is the wrong place. Thanks
Thanks but I did find these. The only thing that conserves me about these is the contact rating. 0.3A @ 12V. The original one that was in place is an omten and it's rating is 1A @ 30V. Don't know if I will have the same problem.
This is on a single 18650, Cree flashlight so it's max is probably running about 1A @ 4.2V.
mine is an OEM switch and its rating is 1A @ 30 VDC and all it is running is 4.3V but I grounded out the led so it melted the switch.
do you have any of these left? I just tried to order one and they wanted $15 shipping
Hint for Digikey orders: Use U.S. Mail first class for small/light items. Postage for 5 18650 holders was $2.50.
I'm also looking for a switch. Something SPST with press-on that has a momentary 'off' press to switch modes on a multimode controller. Current will be about 2 amps (SSC P7 at 4.2 volts). Can't tell if this would do it:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=526PB-ND
Another handy thing: PTC fuse protection. Automatically resets when overcurrent condition goes away. Cheap, too.
Used what I had, time to get more.
