So which drivers would you use in which circumstances?
This is what I really want to know.
I know I answered this above,but I thought for prudence and safety's sake I should expand on the answers.
Your looking to drive an MC-E at full power from either a 18650 or 17670.To know if a driver will work with a particular battery,and whether or not it wil be safe,you have to determine the current input requirements.(not speaking of voltage issues mentioned above,those )
Heres the formula:
Power output=number of chips/dies/emitters x Vf x current
Power input=Power output (watts)/efficiency
Input Current=Power input/battery voltage
Series Example:
Power input=4 dies x 3.5Vf x 700ma(.7)=9.80 watts
Power Output=9.80 watts / 85% (.85) efficiency=11.53 total watts out
Input current=11.53 watts / 3.6v (nominal batt voltage)=
3.20(3200ma) amps in
Parallel Example:=1 die(because of parallel) x 3.5Vf x 2800ma(2.8)=9.80 watts
Power input=9.80 watts / 85% (.85) efficiency=11.53 total watts out
An AW 18650 is 2200mah,that means the max safe discharge is 4400ma(2C),so that configuration would be within allowable limits.
An AW 17670 is 1600mah,that means a max safe discharge of 3200ma(2C),At the max safe allowable discharge current from the battery.
The battery voltage will drop a little lower than 3.6v during the full discharge cycle,when this happens,the current requirements will increase.With the 18650 you have some headroom,the 17670 is maxed out.Whether or not this will work and be safe could be better answered by someone other than myself.
Also,at 3200mah discharge,your looking at a half hour runtime.To be useful as an EDC multiple levels would be required to stay out of max for normal situations.
Just wanted to give you the numbers so you could see whether an application would be safe and what runtime to expect.
-Michael
