tron1974
I searched the forums and didn't see this posted. I did a search on "Cree" on the Coleman site and found a few press releases.
FACT SHEET - LED Flashlights
Coleman combines significant advances in LED technology and battery technology with its own patent-pending design to produce two bright new flashlights. In addition, the versatile beamed LED lights can be simply converted to a lantern that provides area lighting by attaching a collapsible, reflector device. The collapsible lantern attachment is sold separately or as a combo. Available early 2008.
Exponent 1 CR123A Lithium Flashlight
Cree XLamp® XR-E LED – 105 lumens* of light on high
Five 3mm red LEDs
Operates on one CR123A lithium battery, included
Weight – 2.8 ounces (with battery)
Illuminates – 6 hours on low, 1.5 hours on high
Milled aluminum body. Weather resistant
Patent-pending tail cap for easy attachment to lanyard or key ring
Tail cap also has "smart" switch for Off/MomentaryOn/Low/High/Strobe
Selector dial to change light color; also electronic lock
MSRP: $59.99
Exponent 2 CR123A Lithium Flashlight (same features as above)
Cree XLamp® XR-E LED – 155 lumens* on high
Operates on two CR123A lithium batteries, included
Weight – 4 ounces (with batteries)
MSRP: $69.99
Exponent Collapsible Lantern
Attaches to Exponent CR123A Lithium Flashlights to create lantern lighting effect
Weighs only 1.2 ounces
Conical reflector diffuses and distributes LED beam to provide flood light, area light
MSRP: $9.99
http://www.coleman.com/coleman/ColemanCom/newsrelease.asp?releasenum=398
FACT SHEET - Bike/Pack Light
Coleman introduces a multipurpose LED light that can be easily fastened or clipped on a bicycle, a belt or a backpack for adding visibility and illumination to increase safety for hikers and bikers. The lightweight but bright unit has a high or brightest setting that produces 75 lumens* of light, plus a low setting, and an emergency blinking strobe setting.
Cree XLamp® XR-E LED – 75 lumens* of light on high
Three 5MM LEDs for low setting
Metal clip for easy attachment to backpack, belt or bike
Four-position switch: Off/High/Low/Emergency Strobe
Weather resistant
Operates on three AAA batteries, included
6 ounces (172g) without bracket
Illuminates 20 hours on low, 5 hours on high
MSRP: $34.99
http://www.coleman.com/coleman/ColemanCom/newsrelease.asp?releasenum=397
FACT SHEET - 3AAA LED Multi-Color Flashlight
Lightweight yet multi-functional, this small LED flashlight is designed for years of service in pursuit of great outdoors activities. Weighing in at only three-tenths of a pound, yes just 4.8 ounces, this little light uses the latest in LED technology to product 65 lumens* of light. A simple twist
of the front housing switches color options from the bright white light for general purposes, to a red light for enhanced night vision, to blue for map reading or following a blood trail.
Cree XLamp® XR-C LED – 65 lumens*
Rugged but lightweight anodized aluminum body
Run times: 6 useful hours on white, 50 hours on red, 50 hours on blue
Weight: 4.8 ounces (with batteries)
Weather-resistant
Rotating bezel changes light color
White light for general purposes
Red for enhanced night vision
Blue for blood trails
MSRP: $29.99
http://www.coleman.com/coleman/ColemanCom/newsrelease.asp?releasenum=406
Five 3mm red LEDs
MSRP: $59.99
MSRP: $69.99
MSRP: $9.99
Weather resistant
MSRP: $34.99
Weather-resistant
MSRP: $29.99
