- Joined
- Jul 15, 2007
- Messages
- 591
Not quite the application they intended, I fear, but I did find this buried in some documentation I was summarizing for wall wash apps.
http://www.lumination.com/literature/Immersion_RV30_PS1700Install_WEB_121508.pdf
http://www.lumination.com/literature/Immersion_RV30_SpecGuide_WEB_011409.pdf
GE-PS1700NCMUL-SY
Input Voltage (VAC) 90 110/120 265
Input Current (A) 0.3 0.55 1.0
Input Line Frequency (Hz) 47 50 to 60 63
Reach-In Output Voltage (V) 40 43 46
Tall Reach-In Output Voltage (V) 47 51 55
Output Power (W) 80
Output Current for Dip Switch Test Mode (A) 0.3
(factory default)
Output Current for Dip Switch Low (A) 0.6
(1 center light OR 1 end light set)
Output Current for Dip Switch Medium (A) 0.9
(1 center light and 1 end light)
Output Current for Dip Switch High (A) 1.2
(2 center lights OR 1 center light and 1 end light set)
Total Harmonic Distortion <20%
Power Factor >0.9 0.95
Operating Temperature Range (°C) -40 C 50 C
Storage Temperature Range (°C) -40 C 85 C
Basically- 1.2A max output, 80W.
Now to find out how much these strips cost... I'm they come in (6" increments) but seem to be available as standard lengths as well- 6'. If they use 4W LEDs (3.6W) they have 3x units running at 350ma a piece in each dome- there are supposed to be 7w units available as well but I haven't received anything about when they're available.
GE-PS1700NCMUL-SY
Output Power (W) 80
(factory default)
