New E2E, Questions??
tracker870
New England
Received my new E2E-HA (my first Surefire) yesterday along with a box of SF123A bats, and an F05 red filter. This is for starters, LED KL1 head later? First, Wow! This flashlight has a super bright beam!
I've had a cheap knock-off Xenon tactical light (6P-like, 5.25" bulky/heavy, w/tail cap mom/twist sw) for a couple of years, and I always knew the beam was subpar (dark spots etc.), and now that one is going in a drawer.
I also use the assorted Mags & mini-mags.
Anyways, back to a question re: the E2E..
Lockout feature: The card & booklet instructions describe aligning notches & witness marks, but the E2E only has a witness mark on the tail cap. I found that aligning that mark with the belt clip works. So, is this normal?
Also, the seam on the bezel appears to have what may be glue or epoxy oozing a bit out of the seam? I wiped it down, as it was a bit tacky to the touch. Is this normal?
Overall, very impressed with this light, and actually, I really like that greenish hard anodized finish.
tracker870,
Welcome to CPF /ubbthreads/images/graemlins/wink2.gif
Some lights have witness marks and some don't, you probably have the new body style. I wouldn't worry about it. You probably won't even use the witness marks when you get used to your light.
When I lock mine out, I just turn & test to make sure it's locked out.
It's not normal for the epoxy to be oozing out.
The E2e is a great light. Enjoy!
Thanks! I got this one direct from Surefire, so I expect it's a fairly new one. It does have the Pyrex vs. Lexan.
There wasn't a lot of that epoxy; I just wiped it off, it's shiny stuff in the seam.
As I said, this is my first Surefire. I'll budget for a second in the Spring! /ubbthreads/images/graemlins/cool.gif
I don't think it's epoxy. Epoxy dries, sets, and bonds things together. Perhaps it's just a little too much silicone lubricant for the O-rings?
I agree with KelvinL, tracker870. I think the stuff is silicone grease rather than epoxy. Mine had some at the base of the bezel when I took it out of the sealed box too. I don't think you could've "wiped" it off if it were epoxy /ubbthreads/images/graemlins/smile.gif
Silicone grease makes sense. Initially, I was thinking, some pliable form of glue, for heat expansion & cold contr., but that would still solidify to some extent.
I too just the other week received a brand new E2e direct from Surefire, and it has the new body style. I am more than pleased with it, and in fact I can't find anything wrong with it. I hope you enjoy yours, as much as I truly enjoy mine.
I'm extremely happy with my new E2e that I got from Chris at Meridian Tactical. Great EDC size, great light.
New style looks better in my opinion.
i have been drooling over the E2E for some time...
small, bright, pocket clip.
that is one SWEET looking light...and modular!
Bob
I got a E2D and I love it!(see my post) killer! tracker, did you know it was going to be that small! VDG
get the E2E..then get a KL1...then get a KL4...then you need more 2 X CR123 bodies.....then a 1 X CR123 body with a Z57 for the KL1 and one for the KL4...... /ubbthreads/images/graemlins/smile.gif
Welcome to CPF tracker870, and why dontcha stay awhile!
Yeah, this is only the beginning fer ya, Surefire, and great lites, are an addiction, specially around here!
welcome again,
daloosh
Thanks for the welcome daloosh!
Hi voodoo, Had a good idea what I was getting after reading a bunch of the posts here, and using the Surefire comparison chart. They sent me a catalog with the order.
Can you say, Xmas ideas?
[ QUOTE ]
Bob
[/ QUOTE ]
Very modular
Definitely get the KL1. The newer ones have pretty nice high domes in them. The only modification that I would consider necessary is the addition of an 17mm IMS reflector. Other than that, it'll be pretty bright and give you a hellacious runtime.
kind of a silly question, but does the KL1 run ok on the E1E?
i may just have to get both!
Bob
