I'm just giving you some general input range. You need to take into account the internal battery resistance and output power to determine if a configuration will work.
Stripping out the configurations, the technical preliminary specifications are:
Vin: 2.5V - 6V.
Iout: 400ma - 1A (Set by a low value sense resistor).
Vout max: ~6V.
Vin max: 6V.
Iin max: ~2A NOTE1
NOTE1: Due to size constraints the Iin limit is dictated by the inductor and not the IC. For those serious hackers out there, substituting a larger inductor will allow you to pull more power.
cy,
I would without a doubt totally discourage any 5W usage at all with this driver. The IC is a low voltage device and the semiconductor process has been optimized for usage in the 3-5V range. Operating the semiconductor fabrication beyond the 6V limit will probably kill the IC. Like I mentioned above, there are more elegant solutions for driving the 5W.
Don,
You are correct in that a regular 123 has been shown to not be able to support high current demands. That doesn't preclude one from making a wiz2 400 and a 123 combo. The 400, 500 and 750mA Wiz2 drivers might be fine with a 123 even tho you may not get the full battery usage. But, in a pinch, if you were using R123s and the light pooped out a regular 123 could stave off a very dark situation. I know it's marginal. 1A from the 123 would drop the battery voltage to 2.5V right off the getgo. So, only light duty versions would be applicable for this usage.
That would also apply to 2 NiMH AAs or even 2 regular AAs. Fresh they might be 3V open no load, but, under load could drop to 2.6V or so. That's been my experience with the testing I've done on the bench. Under these conditions you might get 10 minutes of runtime before it cuts off and I mean it cuts off. Right at the corner is very interesting. The IC cuts off. Since the load has been disconnected, the battery voltage rises and the IC starts up again. This results in a flashing light mode. It's definitely a warning to change the batteries.
Remember that your applied application dead battery condition should be 2.5V or higher. In that way you will squeeze all the juice out of the battery. If your take a 2AA battery setup the dead state has been accepted at around 1V/cell or 2V. That is below the 2.5V minimum input and you will not tap all of a 2AA setup.
A R123, Li-ion, Pila etc start full charged around 4.2V and are considered dead somewhere below 3V.
A 3AA or 3 alkaline would start at 4.5V which is within the 2.5V - 6V range and the dead battery state would be 1V * 3 or 3V. That too is within the 2.5V - 6V range and would be a good combination. So, 3AA, 3C, 3Ds would all be great candidates with this driver. Mag3C, Mag3D, Mag4C, Mag4D all 2X123 lights. 1X123 using JSB's Li-ion batteries. I think that should help enlighten some ideas and general constraints of where this driver could be used.
The end target of the board diameter is to keep it the same size as the BB, DB and MM series. Currently the prototypes are a tad bigger.
Wayne
