mark33
Hi - I have a couple of questions which somebody may be able to help me out with.
I have read a few comments on here about how good the Inova X1 is. As I don't want to damage my Gladious at work I brought an X1. The first one, new generation 2W, had to go back to the shop because it would not go into constantly on mode instead it kept flashing which is fairly irritating. Replacement arrived and for the first 10 minutes or so all was fine with a good constant on beam. After this initial 10 minutes the torch now flickers/strobes with differing speeds and rarely goes into constant on. I put a new battery, standard duracell AA, and it goes well for 10 mins then starts flashing again.
Am I doing something wrong, should I be using high capacity rechargables (>2700m ah) or are these X1s just rubbish?
I am thinking of replacing it already for a Fenix and like the single CR123 P2D-Q5. Will this torch allow me to use rechargable 3v CR123? If not are there any decent lights that will allow me to use such rechargables as in the UK these batteries are quite expensive?
Thanks in advance
Mark.
Thanks in advance
Mark.
