Hello. I am new here and a casual flashlight user. I am looking for a flashlight that would be good to take a new puppy out with at night. Any suggestions? Thanks!
Hey Walt.I want a flashlight that will offer different features such as different level of brightness, I like the idea of rechargeable instead of keeping batteries stocked. I also think having different brightness is useful. I don’t want a magpul like my dad kept in his truck as they were big, and only remember them having one setting on or off.
What do you think of the wurkkos brand in general - as I saw the post about the FC12 - and thought the color was unique easier to spot, and met a few things…just seemed cheaper than some of the other lights I've researched.
Small backyard that backs up to the woods. There is a lot of wildlife in the woods that I want to make sure I can see at night for bathroom trips so not a lot of time spent outside when it's dark.What is your terrain? How far away do you need to see? Seems like a good idea for decent color rendering to see the quality of the puppy stool! Multiple levels is definitely the way to go. How long will you be outside at a time? Not having to spend time removing the battery from the flashlight is nice when recharging, but not a big deal if the flashlight you want requires it.
Thank you!Sounds like you do not need a lot of runtime for that application, though you may use the flashlight in other ways. It is a challenge to see through branches and brush with a flood type beam; one's eyes get blasted by light bouncing off the foliage in front of you. Consider a torch that has a fairly tight hotspot that will pierce the nearby vegetation so you can see critters that are further in from the edge of the woods. Can you get by with a multi-purpose beam? Yes, but it is surprising how much better a tight beam looks past the close stuff. I would say definitely do not get a flood type flashlight. Inch and a half (or more) reflector size, deeper reflector with a small head, and/or a smaller sized LED will help give more throw. A little bit of faint spill is fine and should make for a more pleasant tool to work with, as opposed to a very tight beam with no spill at all. The advantage of a thrower is that longer distances, when they arise, will be handled. Later you may decide on a flashlight with a wider cast for very valid reasons.
Thank you! That's not him, but it looks similar to him. I'll have to change it to a picture of him instead.Hi, Walt, and welcome to CPF.
We got a 6 month old pup about 2 months ago, and I've found my older (with XM-L) Armytek Viking Pro has been great for finding the doggie doo against brown, hibernating grass in winter, even with a few leaves around. Summertime remains to be seen, but no hi-CRI needed as of yet. I always have it on level 3 out of 4 (not including turbo). Flashlight in the left hand, plastic bag in the right... lol.
What's been working for me is its fairly tight hot spot for centering in on small objects, and the spill is bright and just wide enough at close quarters to help prevent stepping in anything. It'll also easily throw across the yard when needed, even on level three. If you get something with similar features, I think you'll do well given your stated needs. I agree with Kitro on the tight beam with a bit of spill. One other thing to consider is whether your light will have memory. For this scenario, I do prefer the light to come back on at my preferred setting.
BTW... if that's your new pupper, he/she is super adorable. And look at the size of that left front paw!
