Phantomd aka zach
I am an avid off-roader (4-Wheeling) and I want to build some "Rock Lights"
(Basically a way to illuminate the ground under my truck at night)
These will not be used to make my truck look cool, they will be purely utilitarian!
this is a similar/identical project
http://www.candlepowerforums.com/vb/showthread.php?t=196510
Goals
Questions:
here is a picture of a product made by Vision-X, this is the effect I am looking for but I want something brighter, thus the CREE Q5's
http://www.wanderingtrail.com/Mods/JKmods/Tantrum/images/IMG_3641.jpg
-Zach
Goals
- I want to use 8 or so CREE LED's with a chunk of aluminum as a heatsink and a chunk of lexan or similar plastic as a "lens"
- Simple to wire to the 12V system
- Bright
- as FLOODY as possible, the distance from the light to the ground would be about 2-3' (this will probably depend more on my "lens" which is basically a frosted lexan cover)
Questions:
- I hear the buck pucks by LUXDRIVE are common and easy but I was wondering if there was a cheaper way, also how do I wire these? do I need one per LED? is there a cheaper LED buck driver that I can use?
- I want to make these so I can wire 12v to the led assembly, this will be switched, if this is exceptionally more expensive then I will use one driver for more then one LED.
- I am not worried about the mounts, I understand that I need a decent heatsink and use thermal epoxy to mount the LED to the heatsink, thats not the issues... I am a mechanical engineering student and sorta struggle with the electrical world.
-Zach
