Codswallop
Hello all from the (not so) sunny UK. New here 1st post - facinating forum(s). I am in the early planning stages of building an led fishing headlight. I suspect that the final design/specs will have to be dictated entirely by the availabilty of parts. What I would ideally like to be able to do is create a two mode (high/low) light using a 3 pole on-off-on toggle switch. I have built similar in the past, but using two separate halogen bulbs direct driven. This time I would like to use a single led or single led array (if that makes sense!).
To this end I wondered if it is possible to say - direct drive one 'channel' for high power, and route the second 'channel' through a low output single mode driver running a single common return to the battery through the driver?.
I have only basic electronic knowledge and no experience of using drivers, so am unfamiliar with connections etc. Is the method viable? and are there any drivers that could accomodate it?. I will upload a drawing as soon as I am allowed.
Led considerations at the moment are: Triple Cree XR-E R2 or single SSC P7.
Existing battery options available are ideally 3 or 4 cell AA nimh enabling headband mounting, or (a poor 2nd), 10 cell C or 1-10 cell D nimh waist mounted.
Any early thoughts or observations from you enlightened folks would be greatly appreciated. (Phew!).
