you need:
clean parts
electrical solder (none of that stuff use with torches or anything)
leads must be hot too. hot solder doesn't stick to cold metal.
that's the bare minimum.
Now, let your iron heat up. once it is hot, tin the tip either with tip tinning compound or some solder. wipe the excess off with a wet sponge. I use a paper towel folded over on itself enough to keep me from burning my fingers.
Now, arrange what you want to solder and touch the soldering iron tip to the joint. this will heat up the parts getting them ready to be soldered. You shouldn't need to hold it on there more than a second before applying solder. Try to see if the joint will melt the solder. If not, you can still melt it on the soldering iron tip as close to the place where it is touching the joint as you can get it. the solder should flow between gaps via capillary action, i guess.
if you are having trouble, let the parts cool back down. you don't want to damage that nice new $10 emitter.
You will know when you have done it right, the solder will pretty much work for you. I reflowed a cree xp-e to an 8mm round board. the xp-e is only 3 or 4 mm^2. I dropped that led on the melted tinned contact pads crooked by mistake, but wouldn't you know it, the dern'd thing oriented itself.
Anyways, try practicing on some wire or something first. solder is cheap. LEDs, not so much.
try sanding the terminals, and dont forget to tin the iron, use flux, etc.
I'm sure a better member will post something better soon.
Welcome to CPF!
mpireone, flux is the secret sauce that makes soldering possible. BTW jason 77, where can I get some of that?This is the Flux I use,
I haven't been to lowes or home depot, but all the hardwares store nearby only carry acid flux. I'll see if I can't get to one of them and see what they have.home depot and lowes both carry solder paste flux for a couple bucks.
it should be in the aisle where they keep the solder/gas torch accessories.
you need:
clean parts
I'm trying to solder the pos and neg wires to the emitter but the darn solder won't stick. What do I need to do to make it stick?
Never mindWhat's FLUX?
Also, please DON'T use rosin core - it leaves a disgusting residue that is hard to determine if you have a good joint. There are plenty of quality no-clean flux solders out there these days that there really is no reason to revert to the old rosin core stuff. The modern no-clean fluxes basically vaporize on soldering and leave no to little residues.
Kester and Qualitek among others have excellent solders (both RMA and no-clean) lead free and lead based to choose from.
A no-clean flux pen is useful to aid in good joints when the no-clean flux in the solder is insufficient for the job. Handy to add a little flux to stranded wires prior to soldering.
For lead based the 63/37 works better than 60/40 - especially if you are worried about a dry joint due to jiggling things while the solder is cooling. The 63/37 has a very fast phase change that makes dry joints a lot less likely.
cheers,
george.
